Order Farmall Cub Parts Online
Cub oil levels
Adam Gallagher
12-22-1998 08:35:54
Ive got a 49 cub and don't have a op's manual yet. Where is the trans/diff oil level "check plug" located? Is there a check plug for the hydraulic lift system, and lastly can ATF be used in the resovoir?. Thanks guy's!!!
RickB.
12-22-1998 16:06:53
 Re: Cub oil levels in reply to Adam Gallagher, 12-22-1998 08:35:54
The trans level plug is on the left side of the trans housing about 1/3 of the way up the side just in front of the shifter. It is a 1/4" pipe plug, if I remember. Don't use ATF in the touch control, it is too light. Find a CaseIh dealer and use HyTran Plus oil. It is the recommended oil, and one gallon will more than do this system. What you save on cheaper and possibly inferior oil won't buy a pump for your Cub.
John Healey
12-22-1998 18:11:17
 Re: Re: Cub oil levels in reply to RickB., 12-22-1998 16:06:53
The hydraulic fill fitting is ao the left top of the touch control unit. When checking fluid level make sure the cylinder is retracted and maintain liquid level about 3/4 inch below fill hole.John
Deutsch
12-23-1998 06:41:18
 Re: Re: Re: Cub oil levels in reply to John Healey, 12-22-1998 18:11:17
John;
I just got my Cub home last night. You refer to "cylinder", "retracted". Could you please define/explain?
Thanks, Happy Holidays
John Healey
12-24-1998 05:00:44
 Re: Re: Re: Re: Cub oil levels in reply to Deutsch, 12-23-1998 06:41:18
Sorry,I meant to say "piston retracted in cylinder". John
Deutsch
12-24-1998 06:37:22
 Re: Re: Re: Re: Re: Cub oil levels in reply to John Healey, 12-24-1998 05:00:44
Gunked down the Cub last night, really something else. Started right up, loving it!
