F-20 Cooling System
Al P.
03-29-2000 13:55:34
I am just starting a major overhaul on my F-20 and have Dissasembled the radiator and have taken the head off the block. there is lots of chucks of rust everywhere. i intend to rod out radiator core, and have knocked a lot of big chunks of the head but am limited in access on the block. is there a chemical or a method to clean up and prevent futher build-up of rust. i would like to thourouly clean up before reassembly.
Al P.
RAW in IA
03-29-2000 19:13:18
 Re: F-20 Cooling System in reply to Al P., 03-29-2000 13:55:34
If you are going to pull the sleves you can get at the inside of the block to clean it out, asit has wet sleeves. I would probably be a good idea to pull them anyway to reseal them to prevent future leaks. When my brother pulled ours, the rust was almost halfway up the sleeves. We also pulled the tankso off the radiator because we had to replace the core. Had fun drilling out and tapping someof the holes. but it works great now.
