H carb.
b.runyan
12-09-2008 16:04:14
I posted the other day that the H I spent 2.5 years restoring would not run right at high speed, thought it was a main fuel adjust or jet problem, well I had a light bulb go off today over lunch. I didn't remember seeing the venturi tube the other day when I took the carb. apart to look again. Pulled the bowl back off after lunch and NO venturi tube, it was still in the carb. cleaner from 2 years ago, I can say it was clean. Put it in and she runs like a top. A wash job and decals and a choke rod and it's done. While I'm here, anyone know the correct routing of the choke rod?
