No Power !
bronco
04-02-2000 16:55:37
I took the Cub out for the first tyime this week after sitting most of the winter to fertilize and roll the lawn and it won't pull --- The slightest grade with the cement roller attached , it just has no power to pull. Even with full throttle and in 1st gear, I can't get up the slightest grade, any ideas where to start kooking ???
Rick
04-02-2000 17:21:28
 Re: No Power ! in reply to bronco, 04-02-2000 16:55:37
Sounds like a cub,trade it off for a real tractor. That is if you need power.
Bill {Antique Acres}
04-02-2000 17:20:08
I had the same problem with my 48' Cub last year. I would start with all the common things. Make sure you are getting a good flow of gas, try adjusting the carb, check your plugs and make sure you are getting good fire. Replace your points. Check your oil for water, in my case my I had a head bolt break and caused it leak antifreeze in the cylinders. Report back what you find. Good luck Bill {Antique Acres}
Justin
04-02-2000 19:24:00
 Re: Re: No Power ! in reply to Bill {Antique Acres}, 04-02-2000 17:20:08
My Cub is the same way. It sit all winter then when spring comes it won't run. I let the cub run for a while, let it get hot. Then slowly start working the tactor. After an hour or two it will run fine.
I pull a 1500lb. yard roller with my cub, and pulls it with no problem. The Cub is just sick from siting all winter.
Ludwig
04-04-2000 13:47:23
 Re: Re: Re: No Power ! in reply to Justin, 04-02-2000 19:24:00
I agree that the Super M also seems to run poorly at first in the spring. I usually let it have a nice long slow warm up. I also add just a little bit of carb cleaner to the fuel.
My Great Uncle Pat used to add a pint of diesel fuel. The tractor would spit and cough and sputter and have great clouds of smoke, but then run better.
p
04-02-2000 22:48:29
are you sure it is not just corrosion on the points and bad gas in the system...sounds like time for some maintenance...also is the govenor stuck? is it reacting to the pull on the motor?..let us know...p
