756 3-point hitch problem
Adam
04-03-2000 18:09:03
The hitch raises fine sometimes, other times the high pressure relif valve pops off. have tried other relif valves all are the same. doesn't matter if it has weight on it or not help?
Les Repair
04-06-2000 17:25:36
 Re: 756 3-point hitch problem in reply to Adam , 04-03-2000 18:09:03
It almost sounds liuke something is binding in the hitch on the outside of the tractor. When it goes under pressure as you describe, see if you can lift the lift arms manually.
