1086 digital dash
Brian
04-08-2000 22:36:18
Recently purchased a 1086 with front wheel assist.Tractor has a digital dash board that doesn't work right.As tractor is running rpm readout does't change ,number may be different each you start it.Anyone out there that has had this problem or know anyplace that can repair them? This is my first post.THANK YOU in advance.
Justin
04-09-2000 09:02:05
 Re: 1086 digital dash in reply to Brian, 04-08-2000 22:36:18
On the right side or the motor (alternator side)on the back, there is a plug with about four or five wires. These wires run part on the digital tack. Clean the pulg and check the wires. On my 1086 my tack won't work, this plug fixed my problem.
Larry24d
04-09-2000 07:38:18
I wonder if perhaps your rpm sensor is bad?? If they work like trucks...you should find it on the flywheel cover...you could start the tractor and use an ohm meter and see if its working. Just a suggestion, beofe going to alot of time and trouble. My 2 Cents...
tom
04-09-2000 06:13:02
ag express can fix it look at www.agexpress.com
Dave
04-09-2000 03:46:54
Your Case IH dealer can get them fixed for you
