H charging system check
brian
04-12-2000 12:01:34
anyone know how to check charging system on farmall H with original 6 volt system? also whats the deal with low and high charging? i don't think its charging i charge the battery and the it last a week or so then i have to recharge thank you ....
brian
04-16-2000 18:50:27
 Re: H charging system check in reply to brian, 04-12-2000 12:01:34
well got the tractor to charge but now the ammetter reads backwards
The Red
04-12-2000 12:24:45
Brian usually you keep the high charge on high. I have only seen one 6 volt generator charge at around 20 amps and so I dropped it to low charge to bring it down to 10 or so. Otherwise that low is not needed.
After you got the beast running, unhook the battery cable, at the battery, that goes to the starter switch. If she stays running, you are charging.
brian
04-12-2000 12:36:50
 Re: Re: H charging system check in reply to The Red, 04-12-2000 12:24:45
the pulling the ground while its running gives you a rough idea if it's charging but no idea if it's right alos what about mine having a magneto it should run without a battery
Bob M
04-12-2000 14:21:58
 Re: Re: Re: H charging system check in reply to brian, 04-12-2000 12:36:50
If you have a voltmeter, hook on lead to each battery post. With the motor at full RPM you should see 7 to 7.25 volts if the generator is working right. Less than that says you've got a problem.
If you don't have a voltmeter, you can get a decent pocket digital multimeter $25 or so at Radio Shack - well worth the expense for diagnosing tractor electrical problems!
The Red. OOPS
04-12-2000 12:40:51
Forget who has what. You are correct. It should stay running with the mag.
Welllll , if you have lights, they should stay illuminated with the cable off if she is charging.
If you don't have lights, then you will need some sort of meter to test.
