SM regulator
Bart
04-16-2000 04:49:29
Will a 6 volt regulator,(the steering post one) from an M fit a 6 volt SM 6 volt system. Is there any other ways to compare M & SM parts on the web if I don't have all the manuals? I do have all the M manuals. Thanks for any leads.
Ludwig
04-16-2000 07:00:49
 Re: SM regulator in reply to Bart, 04-16-2000 04:49:29
When I bought the last regulator for our Super M the guy just said "positive ground 6volt regulator, Check!"
So I'd presume that a six volt positive ground regulator is a six volt positive ground regulator.
I kind of lucked out, our Super M is a '52 and in many ways is more like an M than Super M. The battery is under the gas tank, but its got the later foot starter switch, hydralics are like an M, hence battery placement, but the IH symbol on the front is like a Super M. Overall its kind of a neat tractor to have.
Bart
04-16-2000 14:33:27
 Re: Re: SM regulator in reply to Ludwig, 04-16-2000 07:00:49
Thanks Ludwig, My SM is a 53. Battery under gas tank foot starter lever, but with live hydraulics with resevoir also under gas tank. Also has the lift-all. Runs like a top. Just have to clean and paint. This is going to be a good summer. Thanks again.
Ludwig - REALLY?
04-17-2000 05:49:25
 Re: Re: Re: SM regulator in reply to Bart, 04-16-2000 14:33:27
Huh?
I thought that the battery got moved under the seat to make room for the live hydralic resevoir. I also thought that once live hydralics came in you couldn't get a lift all...
Shows how much I know.
Bart
04-17-2000 11:43:12
 Re: Re: Re: Re: SM regulator in reply to Ludwig - REALLY?, 04-17-2000 05:49:25
Ludwig, I forgot to mention, there is no belt pulley assembly, so it has the room for resevoir.
Bart
04-17-2000 11:39:21
Don't know if it was added later but they are there Plain as the nose an my Super M. If I ever get it painted, I,ll post a picture.
