Trans. add oil plug.
alan
04-19-2000 14:58:21
My tractor is 250 miles away and I forgot to measure the square hole that is in the top of the add fluid to the transmission housing. Can someone let me know the size? It would be really appreciated. I need to take a tool with me so I can get some kerosene in there to soak. Thanks again!
Paul Shuler
05-24-2000 13:22:22
 Re: trans. add oil plug. in reply to alan, 04-19-2000 14:58:21
I just did my 1953 Super C last Sat. and borrowed a 3/4 inch drive from my neighbor that worked great.I thought it would be real tight but it was just a little tighter than finger tight.The drain plug on my C took a half inch drive and I think the plug to check the level took a half inch open end wrench if Im not mistakin.If your tractor is like mine you wont belive the nasty junk that will come out of there. I let it all drain then put a little kerosene in and drained it again and left the plug out over night and got another quart of nasty sticky rusty goo.
Greg Meadors
04-19-2000 22:13:47
The H has a 3/4 square socket. I use my 3/4 drive wrench and it works perfectly.
TxFarmall H
04-19-2000 19:12:51
Alan,
On my 49 H the plug is bigger than a 1/2 inch drive I found a tool to take it off in the tool box on the tractor it was about a 3/4 inch piece or stock with a 1/2 inch drive attachment on top to put your rachet or breaker bar on to get it off...good luck ....Jason
Dave
04-19-2000 15:07:31
On my 'A' it's a half-inch square hole. I use a half-inch socket-driver with an extension to open it. Other tractors may be different.
Farmer Bob
04-19-2000 21:46:54
 Re: Re: trans. add oil plug. in reply to Dave, 04-19-2000 15:07:31
Alan, I used a 1" pipe plug with a square top that fit perfectly into the square hole in the tranny fill plug. Then used a pipe wrench on the pipe plug to turn the tranny plug out. Might want to try using some Kroil penetrant on it first to get the rust/crud desolving. 3/4" square stock will work too like Dave said. Good Luck.//FB
TxFarmall H
04-20-2000 04:40:18
 Re: Re: Re: trans. add oil plug. in reply to Farmer Bob, 04-19-2000 21:46:54
Thanks Farmer Bob but I said that I use 3/4 inch stock to remove mine on my H don't mean to be rude but, I am new to tractors and am just glad I knew what I was talking about...Jason
Farmer Bob
04-20-2000 22:53:48
 Re: Re: Re: Re: trans. add oil plug. in reply to TxFarmall H, 04-20-2000 04:40:18
That's what I get for trying to read/respond to these threads late at night after a long days work like many others. Important thing is what you tried worked and you had it right there in your tool box.//FB
