Farmall H float
Bill
04-23-2000 03:03:45
Does anyone know where I can buy a float for my H carb.? Mine is full of gas.
rob Vallance
04-23-2000 08:02:39
 Re: Farmall H float in reply to Bill, 04-23-2000 03:03:45
just a thought but you can drill small hole (use a hand drill electricity and gas do not do well!)and empty and dry out your existing one (carb cleaner will evaporate rather quickly in the sun for a few hours) and then resolder your existing one. the way to test it for leaks is fairly simple just tie it to a wieght and then submerge. use something with a low specific gravity like soapy water. plain water has a high specific gravity and will not seep well into small openings like gas will. good luck and i have done this before when i was unable to get a float easily on a hunting truck (old jeep that is hours from the nearest parts store if they would even have one in stock)
Tim W
04-23-2000 03:30:21
Bill, Try Dave Reed at otto@dol.net
The Red
04-23-2000 03:28:36
Bill your best bet would be to call IH Ken Updike at 608-455-2411. If he cannot get you one, try Gary Biewer for a used one at 218-937-5627. Let us know where you can find one since I have never seen one in a carburetor kit.
tim
04-23-2000 16:55:10
 Re: Re: Farmall H float in reply to The Red, 04-23-2000 03:28:36
the floatis still available from ih dealer but youll pay around thiry dollars i just bought one for a M carb.
Rich Griffin
04-25-2000 19:52:19
 Re: Re: Re: Farmall H float in reply to tim, 04-23-2000 16:55:10
How many floats do you want? I have three good used ones.
