Pto ?
bob (pa )
04-24-2000 16:40:10
this may sound dumb but does farmall cubs have a rear pto for drive shaft hook-up thanks in advance
Wardner
04-24-2000 21:25:08
 Re: pto ? in reply to bob (pa ), 04-24-2000 16:40:10
third party image
If you want standard PTO for a Cub, buy one of these. They are made by Hub City of Aberdeen, SD. They are available through most industrial bearing distributors.
POTOSI
04-24-2000 16:52:40
YES THEY HAVE A PTO,HOWEVER IT IS A SPECIAL SPLINE AND IT ROTATES IN THE OPPOSITE DIRECTION FROM MOST OTHERS.
Harold H
04-24-2000 17:32:44
 Re: Re: pto ? in reply to POTOSI, 04-24-2000 16:52:40
It also turns at engine rpm rather than 540 rpm.
Harold H
Chris
04-24-2000 17:46:12
 Re: Re: Re: pto ? in reply to Harold H, 04-24-2000 17:32:44
Isn't the spline diameter a bit smaller than standard? What a goofy little tractor. But then again, maybe they designed it that way so friends like mine wouldn't try to hook a New Holland baler to my Cub.
Harold H
04-24-2000 18:47:05
 Re: Re: Re: Re: pto ? in reply to Chris, 04-24-2000 17:46:12
The shaft is smaller, but you are only looking at about 10 pto hp. Wouldn't do much with a baler anyhow, even if it hooked up.
Harold H
