2 Types of Front Rims for H
Aaron
04-25-2000 06:27:40
This is my first attempt in restoring a tractor and have a few questions. I noticed in my parts book that IH made 2 different styles of front rims for the H. One is called an adjustable front rim which has what would be the clamps welded/rivetted into the rim itself. I have seen this style on a '45 and also a '46. Then, the other type has the individual cast clamps that hold the rim and wheel itself together. I have seen this type on some smaller tractors (A and B) at shows and also on a '44 H. Were either of these types available as an option at any time during the manufacturing of the tractors or was there a serial number break from the factory? I am curious and somewhat confused because I don't see anything in my parts book that splits the options up. Thanks for your help.
Aaron
Aaron
04-25-2000 14:32:38
 Re: 2 Types of Front Rims for H in reply to Aaron, 04-25-2000 06:27:40
Thanks for the info. I guess there really isn't such a thing as a nice clean serial break for the rims. Once again, thanks.
Bob M
04-25-2000 08:45:38
Adding to the confusion: There are two types of adjustable tread front rims, 3-rivet lug (early) and 4-rivet lug (late). Not certain the date when the change was made but I'd guess about 1951 (Guy Fay???).
BTW the 3- and 4-rivet adjustable rims are interchangable; my '53 Super H had one of each when I got it as did a neighbor's '49 H. Recent photos of The Red's '51 H shows one of each style too.
TomH
04-25-2000 17:11:03
 Re: Re: 2 Types of Front Rims for H in reply to Bob M, 04-25-2000 08:45:38
And of course there is another option that my H had when I bought it, as best I could tell it was a "farmer special", clamp type rim with homemade lugs welded on.
The Red
04-25-2000 09:28:34
They were both 3 bolt Bob.
The Red
04-25-2000 07:29:33
You had your choice when you purchased your tractor. My 1945 Indy H has the adjustables and the 1946 Old Red H has the clamps. The clamp type makes it easy to remove the rim but they are a pain to get tight against the rim.
Harold H
04-25-2000 07:12:18
The type with the cast clamps were the standard front wheel type. The adjustable front wheel type was optional most, if not all, years of the H production.
Harold H
