What IS the best?
Aaron Maunumaki
04-25-2000 20:53:23
I am now going to be getting a new tractor. I am looking into a smaller Farmall-(used for pulling a very small trailer,also a belly mower) What is your recommendations on the best,small Farmall?
Thanks
RHicks
04-26-2000 05:18:49
 Re: What IS the best? in reply to Aaron Maunumaki, 04-25-2000 20:53:23
Farmall Cub - perfect for mowing & pulling around a small trailer.
Putt-Putt
04-26-2000 05:10:00
Super A, Super B, 100, 140. 140 was the most modern. All have the capablity to have a belly mower, if they have the offset pulley. Super C is a straight line tractor, it will take a pull behind mower and it can have an offset pulley but I don't think it will take a belley mower.
Phil Auten (TX)
04-26-2000 11:35:04
 Re: Re: What IS the best? in reply to Putt-Putt, 04-26-2000 05:10:00
There never was a Super B. The B was replaced by the C before the Supers came out. Cub, A, B, C,AI any Super, 100, 200, 230, 240 and others will accept a belly mower. The Cub is relatively expensive for it's abilities compared with the A/B, and the A/B don't have hydraulics. The Super A, C and Super C, 100, 130, 140, 200, 230 and 240 would be the best choices in my humble opinion. I have a neighbor with a 240 Utility and a Continental of Belton belly mower that I absolutely covet, even though it's a sin. :o)
Phil
Stillcrazy
04-26-2000 06:09:32
Is there such a thing as a Super B? I'm not an expert, but I never saw one.
Ludwig
04-26-2000 16:35:40
 Re: Re: Re: What IS the best? in reply to Stillcrazy, 04-26-2000 06:09:32
Not a Farmall.
The C being rowcrop negated the need for the B.
By the way Putt-Putt, I've seen a C with a belly mower. Pretty sure it was a Woods setup.
MrG:Yup
04-26-2000 06:33:55
It was built my Dodge...;-)
Paul Fox
04-26-2000 04:01:30
It's as simple as A, B, C
Seriously, any of those, or the 'Super' version of the A or B, or the number series version of any of them would be a dandy machine. Later models have hydraulics, which might be an issue for you.
Paul Fox
04-26-2000 06:50:30
 Re: Re: What IS the best? in reply to Paul Fox, 04-26-2000 04:01:30
Ooops. Meant Super version of A or C
No Super B's, unless you're a Dodge man...
Fm...
04-26-2000 17:02:38
 Re: Re: Re: What IS the best? in reply to Paul Fox, 04-26-2000 06:50:30
Could you take a Super A block, drop it into a B, and then ad the org. front end? then you would have hydraulics, which I understand as being the main difference between the super and org. a..
Ludwig - Durn!
04-26-2000 16:33:52
Was hopeing you wouldn't catch that...
I haven't ragged on anybody all day!
