Can't start BN
bruce fuller
04-26-2000 00:33:24
i have a 1940 farmall BN that started fine 'til yesterday. battery was checked and has plenty of power. there is no response from the tractor at all when i push the starting rod. as i'm waiting on a service manual i could use some internet help. grass keeps growing.
GENE
04-26-2000 19:28:11
 Re: can't start BN in reply to bruce fuller, 04-26-2000 00:33:24
START WITH THE BATTCABLES THEN STARTER SWITCH BROBABLY NEED TO SPEND 30 bucks for a new 625 amp batt check the sp gravity should be at least 1250 on all three cells if one is lower than the rest no good
Ludwig
04-26-2000 16:32:26
Can you pull start it?
Back when my great uncles were farming they used to park all the tractors on top of a hill so they could roll them down to get them started. They told me they saved alot of money in batteries that way.
Bill
04-26-2000 05:00:35
Sounds like the manual start switch jumped up and swallowed its rear end.
Sometimes you can take it off and clean the contacts.
Also, sometimes the starter on my A jams the into the flywheel. I have to loosen the mounting bolts and shake it loose. I carry a wrench in the tool box just for this.
If neither of these work...may as well check the starter, but, due to cost I would do that last.
