674 cool starting
al
12-30-1998 19:51:44
Have 674 that won't start when weather gets cool.
Has block heater, good battery, and eng rebuild last year.
JK MN
12-31-1998 13:24:33
 Re: 674 cool starting in reply to al, 12-30-1998 19:51:44
Al, Gas or diesel? If it is a gas pull the hose off the carb and be sure the butterfly completely closes. Adjust linkage if necessary. If it is diesel, do you put the "run/shut-off" lever in the start position? If you are not familiar with this position, look at the side of the injection pump where the cable attaches to the lever. There should be a small plunger that will push the lever just back from the full stop position. With the lever in this position, extra fuel is delivered to the engine for starting purpose and short warm-up only. Hope this helps.
Chuck Mosher
01-06-2003 07:42:48
 Re: Re: 674 cool starting in reply to JK MN, 12-31-1998 13:24:33
I have a IH 674 with a diesel engine that is very hard starting in cold weather. I purchased a external tank heater since IH said they don't have a block heater for this tractor. Need help finding the water drain plug and another spot for the return line to hook in. Anyone have an engine diagram that might help?
