Can you ID this pump?
Bruce
05-03-2000 19:14:07
I'm cleaning up a deceased uncle's barn and found a gear-type hydraulic pump. Can anyone tell me what tractors/applications this pump fits? I sincerely appreciate any and all help. Thanks!
The part number stamped into the housng is: 367116R92
sammy the RED
05-03-2000 21:01:42
 Re: Can you ID this pump? in reply to Bruce, 05-03-2000 19:14:07
Bruce, Are you sure that is the number ? Take another look.
Bruce
05-03-2000 22:36:50
 Re: Re: Can you ID this pump? in reply to sammy the RED, 05-03-2000 21:01:42
Yep! I re-checked and the stamping is clearly read as: 367116R92. All numbers are cleanly stamped, so there is no confusion. ==== However, there is another set of numbers stamped, which I thought was a serial number. Perhaps I'm wrong, and the real part # is: 051066 01202. === There is also "2854" stamped into a different location, but I assumed that was not a part number, either. ==== Thank you for helping! It is greatly appreciated!
