300U hydraulic reservoir drain?
big fred
05-27-2000 15:51:08
Where is the drain for the hydraulic reservoir on the 300U?
George
05-27-2000 20:55:06
 Re: 300U hydraulic reservoir drain? in reply to big fred, 05-27-2000 15:51:08
300U drain is under the seat adjustment (the delux seat) at the left front of the hydraulic cavity.
You will find it just in front and up from the left brake housing. If you have power steering you may have to remove the PS return line.
Les Repair
05-27-2000 17:26:12
I am pretty sure if you look on the front side of the resavoir you will find a small square plug, such as 1/8 pipe. This is it.
big fred - I saw that one
05-27-2000 19:46:06
 Re: Re: 300U hydraulic reservoir drain? in reply to Les Repair, 05-27-2000 17:26:12
But figured it would leave about 2-3 inches of fluid in the reservoir. I think I'm gonna have to get me one of them hand operated transfer pumps to drain it. I was just worried it was smack dab in the middle of the backside of the reservoir where I can't get at it.
George Willer
05-27-2000 16:00:28
Big Fred,
Just last week I was faced with the same task.. If there is a drain, I couldn't find it. I had the pump force as much as it could through a disconnected hose until it ran out of oil. There was far too much milky fluid left behind so I will have to do it again. Sure hope you find a better answer.
