Moldboard plows
bronco
05-28-2000 19:46:45
Can the Cub- 193 plow be used on the Super A or do you have to use the IF- 194 model ???
gene b
05-29-2000 21:21:08
 Re: Moldboard plows in reply to bronco, 05-28-2000 19:46:45
the cub hooks different the one i have for a SA the drawbar is reversed turned forward and the beam hooks on the drawbar the lift arm on the rockshaft goes back to a brace type that mounts on the rear fenders the arms off this brace hooh to chains that lift up the bottom when the rockshaft is moved forward dont know the number of the plow but have most of the pieces also have some pics somewhere of one on a tractor can send them next tues when i get back home leaving for CANADA IN 1 hour
gene b
05-29-2000 02:41:09
they were different are you talking about a single bottom or a two way
bronco
05-29-2000 08:01:30
 Re: Re: Moldboard plows in reply to gene b, 05-29-2000 02:41:09
Single
