Farmall H battery connection.
A.kiste
06-05-2010 07:04:48
I have rewired my H, 6 volt positive ground with voltage regulator. PO did not have regulator wired correctly and it only ran on the battery charge. With correct wiring should the tracor continue to run if the battery is disconnected? Mine does not.
