Got Super H...need help
Bama Binder
06-05-2000 06:59:46
Just bought a 1954 Super H serial number 26160 with a J suffix...couple of questions...
1. What is the J suffix...I don't see it in any of my books.
2. It has a wide front end on it. I don't know if it is original or not (I know there were several companies that offered aftermarket units). I gave it a quick inspection and did not notice any tags or casting codes that would indicate either an aftermarket or original unit. The one thing I noticed was that the steering gear was on the back of the axle as opposed to the front as in some pictures I have seen of regular Hs with wide fronts. Can anyone give me clues about how to determine the originality of the unit.
3. Any Super H owner...can you comment on parts availability...I can get almost anything for my Cub...but there were so few Super Hs made I am concerned. The parts that I know I need right now I have located.
4. It has the stage II hydraulics....what all can you do with the hydraulics? It has an aftermarket 3pt hitch with only 1 ram.
Bob M
06-05-2000 08:20:45
 Re: Got Super H...need help in reply to Bama Binder, 06-05-2000 06:59:46
Bama - responses to your questions in order:
1 - "J" suffix says your tractor's equipped with a Rockford clutch.
2 - From your description it sounds like you've got an original wide front. My father in law has a '53 with OEM wide front - if I can locate a photo I'll post it so you can compare.
3 - Super H parts are readily available. Many parts are identical to the non-supers. My experience has been parts unique to the Supers (brake parts, oil filters, pistons/sleeves, etc.) are easy to find.
4 - Stage II hydraulics are "live" - much preferred over the Stage I non-live (belly pump) system.
Enjoy your Super H - it's a fine piece of machinery! (I own a '53 Stage 1 narrow front...)
Bob M
Bob M - w/WFE photo
06-05-2000 08:54:24
 Re: Re: Got Super H...need help in reply to Bob M, 06-05-2000 08:20:45
third party image
Bama - Did not find a photo of the Super H wide front. However here is a '53 Super M with factory WF. My recollection is the Super H is identical except a bit smaller.
Hope this helps...
Bama Binder
06-05-2000 09:44:24
 Re: Re: Re: Got Super H...need help in reply to Bob M - w/WFE photo, 06-05-2000 08:54:24
Thanks a bunch Bob...That's the same one that is on my tractor so I am a happy man!! I appreciate the help!
