Farmall b
ARMY
06-08-2000 18:09:58
MY DAD FOUND IN OLD BARN IN NJ WHAT WE THINK IS A 1938 FARMALL B NO INFO ON WWW ON 38'S THIS THING IS NEW AND HAD BEEN COVERED IN BARN DAD SAID IT STARTED ON THE FORTH TRY . NEED TO GET ALL THE INFO I CAN BEFORE I BRING IT TO NC "TANKS"
gene b
06-09-2000 04:15:34
 Re: farmall b in reply to ARMY, 06-08-2000 18:09:58
the serial no is on the block lower and right of #1 plug behing the throtle rod should match the one on the seat bracket or on the clutch pedal cover 1939 were the 1st starting with 501
FASTGUNS
06-08-2000 20:44:16
hey guy do you think it could be an old AC? some models look alot like farmalls. or perhaps the year model is a guess and not correct? either way i hope it goes to a good home. ARMY, please make sure you/your father changes the oil and other necessary fluids before you run the machine. good luck to you.
Guy Fay
06-08-2000 18:36:59
There is no such thing as a 1938 B- in fact, I don't believe there were even prototypes of the B in existence in 1938, and if so, they weren't called Bs. The chassis serial number for the tractor will either be on a plate on the left seat support, or on a plate near the foot rest on the operators platform. A serial number can also be found on the engine, stamped under the magneto on the block.
