FARMALL Pulleys
Bill Wehrman
06-11-2000 21:24:51
Is the belt pulley on an M the same as an H?
sammy the RED
06-12-2000 13:17:14
 Re: FARMALL Pulleys in reply to Bill Wehrman, 06-11-2000 21:24:51
Just a little add to what Gene has told you. There were differant sizes. Most common ones being 6 1/2", 9 3/4", 11" and 12" diameters for the H and M. A 13" dia. pulley was available for the M. With most of the diameters you had a choice of 2 widths also.
Regularman
06-12-2000 09:17:53
Actually, Yes. The size didn't vary depending on the machine to be run. This was done by varying the throttle because these tractors are equipped with a full throttle governor. The larger diameter pulleys orginally came with an M and the small ones with an H. They will interchange though.
gene b
06-12-2000 03:58:18
the size of the pulley for these tractors varried in dia debending on what belt speed was wanted on the machine operated as a hammermill threshing machine ect steel and fiber were avail take your pic
KBBob
06-12-2000 15:37:12
 Re: Re: FARMALL Pulleys in reply to gene b, 06-12-2000 03:58:18
The belt pulley speed of the M is slower than the H. Using a larger pulley on the M will give the same belt surface speed as the H with a smaller pulley.
