Farmall M
Big John
06-14-2000 18:14:15
This may be a stupid question, but I'm going to ask it anyway! On the front grill in the lower part is 4" by 10" opening. Through this hole you have access to the vertical steering torque shaft which has a slot cut in it. My question is what is its purpose and is there a cover that goes over the hole in the grill? Kinda new to this and any help would be appreciated.
RB
06-14-2000 19:43:09
 Re: Farmall M in reply to Big John, 06-14-2000 18:14:15
Quality farm and Counntry has new inserts for 25 bucks.
Big John
06-14-2000 20:09:54
 Re: Re: Farmall M in reply to RB, 06-14-2000 19:43:09
Thanks for all your help!!!
sammy the RED
06-14-2000 18:48:14
The cultivator shifter lever goes in there. Joes Farmall Parts has them.
tim
06-14-2000 18:40:19
various implements used a arm over the steering shaft to turn the snoot. yes there are grill sections available they run about fifty bucks and not to easy to find unless you happen upon a parts tractor some unknowly soul will sell it off of cheap. good luck
Karl in MD
06-14-2000 18:48:00
 Re: Re: Farmall M in reply to tim, 06-14-2000 18:40:19
The hole is for an arm that was clamped and keyed to the shaft. It was forked on the end and a linkage fitted to it steered the cultivators with the front wheels. IH used it from the Regular up til the 50 series tractors.
