Farmall M magneto
Bart
06-16-2000 11:43:02
Can a Farmall M Magneto be checked off the tractor to see if it works? I would think so but don't really know. Thanks. I'm up to my ears in "No Spark".
Ray M41
06-17-2000 10:44:12
 Re: Farmall M magneto in reply to Bart, 06-16-2000 11:43:02
Yes you can. Before you take it off though crank the engine by hand and listen for the impulse clicks. Stop turning the engine just after #1 cylinder hits. You can then take the mag off. I put mine in my bench vise and turn the impulse driver with a little crank jig I made. When you are ready to put it back, turn the mag impulse driver until #1 just trips. then reinsert it. Then fine time it so that the impulse clicks trip on the first mark of the two marks on the front fan pulley. Hope this helps.
Redfan
06-16-2000 13:47:04
Yes it can be. Just make sure you've got the timing set before you install it again. I'd be exhausting all possibilities before I took it off, clean connections,new points and condensor etc.Regards, Redfan.
