Age of a tractor
Betty
06-18-2000 10:10:04
third party image
Hi all,
My husband is restoring what we beleieve to be a 1951 Farmall SM. Can anyone either tell from the photo or tell us how we can find out the exact year of this tractor? Also we need the wide mouth Mason jar that holds gas. Does anyone know were to find one?
Thanks Betty
The Red
06-18-2000 10:20:47
 Re: age of a tractor in reply to Betty, 06-18-2000 10:10:04
Betty look under the oil bath air cleaner assembly to see if a ID tag is on the clutch bell housing. From Guy Fay's book, the earliest Super M was built in 1952. It will have a sn between 501 and 12515. If it was built in Louisville, it will be between 500001 and 501905. If that tag is missing, look around the number one spark plug (closest to the radiator) and you will see an engine sn. It may not match the frame.
Run a WTB on classifieds for the precleaner jar. You will get responses. I don't think you put gas in it though.
From the picture, I see you have disc brakes so a good probability that it is a Super.
sammy the RED
06-18-2000 16:43:15
 Re: Re: age of a tractor in reply to The Red, 06-18-2000 10:20:47
You put little 1/64 scale John Deere tractors in the pre cleaner jar.
Betty Hayden
06-18-2000 10:28:33
Thanks The only plate I can read says
Model SM
Serial # F-23299 J
Max idle speed 1600
Does this help any?
The Red. BINGO!
06-18-2000 10:33:22
 Re: Re: Re: age of a tractor in reply to Betty Hayden, 06-18-2000 10:28:33
Betty you have a 1953 Super M. Serial numbers ranged from 12516-51976 for the 1953 models.
Betty
06-19-2000 05:03:39
 Re: Re: Re: Re: age of a tractor in reply to The Red. BINGO!, 06-18-2000 10:33:22
Thanks for the help.
paul
06-18-2000 18:32:45
my new cub low bow has sn.10061 i am pretty shure it is a 1958 model.but would like verification if any one knows . i want this info to be correct for the registry . thanks
sammy the RED
06-18-2000 22:39:11
 Re: Re: Re: Re: Re: age of a tractor in reply to paul, 06-18-2000 18:32:45
Yup, 1958.
