Tale of Two Coils
Bama Binder
06-19-2000 05:28:05
I just bought a new 6V coil for my Super H. The new one is not like the old one which is much shorter and smaller in diameter. The problem is that the new one is so large it does not fit into the mounting bracket and it rests on the top of both the hydraulic pump and the distributor.
My options are:
1. Find a coil that is the same dimensions as the old one. I would prefer this. Does anyone have a source? 2. Make a bracket that would "fit" the coil I have and have enough clearance to prevent it from resting on the pump/distributor.
Anyone have any suggestions???
mel
06-19-2000 06:59:10
 Re: Tale of Two Coils in reply to Bama Binder, 06-19-2000 05:28:05
I recently bought a 6V coil from tractor supply company and it is the same size as the original on my H. The are on the web. I don't recall the site but you can search for them easy enough.
The Red
06-19-2000 05:31:17
You might give Ken Updike a call. He was trying to get the coils reproduced that originally came on the H. 608-455-2411. I had the same problem on the 51H last year. I used some washers to raise the bracket I believe.
