McCormick W-6, checking oil level
Alex Burachynsk
06-21-2000 08:41:54
Does anyone know how to check the oil level in a W6? I just bought one and can't figure out how to check the engine oil level. There is no dipstick on this model.
Chris Ferg
04-18-2002 13:40:10
 Re: McCormick W-6, checking oil level in reply to Alex Burachynsky, 06-21-2000 08:41:54
underneath the engine were the oil pan is there are one or two little rods there thats were you check the oil level
The Red
06-21-2000 09:14:16
Since that is basically an M engine, there should be two check valves on the oil pan on the distributor side. Oil level should be no lower than the lower check valve and no higher than the upper check valve.
