Farmall 100 smokes thru breather
Bill
06-21-2000 19:30:59
My Farmall 100 puts out exhaust thru the oil breather. Its not extensive, but is a little annoying to smell while driving. What can cause this? Could it be a valve problem?
T16
06-21-2000 21:17:08
 Re: Farmall 100 smokes thru breather in reply to Bill , 06-21-2000 19:30:59
Most tractors emit some smoke from the breather.
It sounds like either blow-by or possably a cracked head gasket, chances are it's blow-by, caused by normal wear, piston rings ain't sealing as good as they should.
Does it smell like exhaust or burnt oil?
Possably could be a real bad valve guide, but chances are you would hear that clattering away.
A bad head gasket would have to be bad into the oil cavaties and would usually cause enuf pressure to blow out a main seal or valve cover gasket.
Good Luck! Hope this helps out.
