Pulling front end off an H
Ben
06-22-2000 04:04:57
Does anyone have any advice as to pulling the front end off of an H. I am trying to access the timing cover and I remove the 4 bolts from each side of the front end. Any words of wisdom will help. Thanks
The Red
06-22-2000 09:48:08
 Re: Pulling front end off an H in reply to Ben, 06-22-2000 04:04:57
Ben make absolutely certain you have the side rails blocked up well and secured. You might have to loosen the engine front supports a tad so the side rails are not as tight against the front bolster. Those side rails slot into the front bolster. Be real careful. That front bolster assembly is very heavy.
