Generator Question
Big M
06-23-2000 08:39:30
I just had my armature replaced on the generator. Was there a gasket on the cover of the armature?
I have a feeling that there should be. Anyone know.
Thanks, Big M
T' Other Fred
06-24-2000 20:08:01
 Re: Generator Question in reply to Big M, 06-23-2000 08:39:30
Glad you asked that question. My Super C doesn't have the gasket under its cover band, and it just might be a good idea to find some material and make one up
Thanks!
Fred
Chris
06-24-2000 20:47:25
 Re: Re: Generator Question in reply to T' Other Fred, 06-24-2000 20:08:01
Believe me, that gasket helps. My starter didn't have one for at least twenty years, and the pitting on the casing where the water sat under the band is pretty severe. After the starter was rebuilt I got some material for the generator and fixed it right up. Chris
Chris
06-23-2000 12:17:57
My local starter/generator repairman gave me a length of cover material. It seems to be textured rubber. He told me to wrap it around, tighten down the band, and trim off the excess on the sides.
The Red
06-23-2000 08:51:32
Are you referring by chance to the band that covers the slot on the generator frame on an H or M? If so, yes. There is no part number for the gasket itself. I don't think all my H starters have had that gasket though.
mel
06-23-2000 12:01:00
 Re: Re: Generator Question in reply to The Red, 06-23-2000 08:51:32
I made one out of gasket material and put the metal band over it. Works good. It helps keep the dirt out.
