DROTT TD-9 CLUTCH PROBLEM
BILL
06-24-2000 13:30:00
I AM LOOKING AT PURCHASING A TD-9. A FRIEND OF MINE HAS THE MACHINE. IT RAN WELL THEN HE FILLED THE HYDRAULIC TANK AND IT HAD A LEAK. IT HAS LEAKED ALOT ONTO THE RIGHT DRIVE CLUTCHES. THEY ARE NOW SLIPPING. CAN THEY BE DRIED OUT AND HOW CAN I TELL IF THE CLUTCHES ARE BAD OR IF THEY JUST NEED DRIED OUT. IS IT WORTH BUYING IF THE CLUTCHES ARE BAD.
Dale13
06-25-2000 06:58:22
 Re: DROTT TD-9 CLUTCH PROBLEM in reply to BILL, 06-24-2000 13:30:00
You can take a good solvent to the clutches ,clean them up best you can then DRY them with a torch,BE CAREFUL.Do this well away from solvent.Don't heat them too much. When done take a wire brush and lightly brush off the residue. Been years since I've done it but it worked then.
