Need rebuild parts for TD-6 timing gear mount Hydraulic Pump
Anton
06-26-2000 10:50:40
I am looking for rebuild parts for the hydraulic pump between the timing cover and distributor on an early 1950s TD-6 diesel(4cyl). It is probably about 15-16 GPM but I am not sure. If you don't know of a source but know if this engine was used in a wheeled tractor, please post the type of tractor so I can cross reference for the pump.
Thanks.
Les Repair
06-26-2000 18:54:38
 Re: Need rebuild parts for TD-6 timing gear mount Hydraulic Pump in reply to Anton, 06-26-2000 10:50:40
I think that engine was used in M and Super M tractors. If the pump has an aluminum housing, it would likely be like the one used on Super Ms. If the pump is weak I think all you can do is replace it. There are some aftermarket pumps which are available that aren't as high priced as Case IH. It'll scare you.
Anton
06-26-2000 22:11:09
 Re: Re: Need rebuild parts for TD-6 timing gear mount Hydraulic Pump in reply to Les Repair, 06-26-2000 18:54:38
Anyone know what aftermarket pumps are available and where to get them (cheap).
Thanks
