Int. 350 Utility
Andy
06-26-2000 16:28:20
I just spent 2 days on a 350 utility w/2 speed hand shift on the left side. There is a chrome decal on the side that says "Torque Master, or Control"...my question is, is this a draft control or just a 2-speed shifter. It worked like a 2 speed. I was box blading up a berm on the edge of a creek and it sure was handy..... thanks Andy
Jon
06-26-2000 17:14:17
 Re: Int. 350 Utility in reply to Andy, 06-26-2000 16:28:20
That is the Torque Amplifier. When pulled back(low range) it decreases the original gearing by 1/3. If a person doesn't know the proper way to shift these, you can burn up the TA clutch after a while. They should always be shifted in and out quickly and firmly, so don't let the clutches slip when shifting. Happy tractoring.
REDHUSKY91
06-27-2000 06:11:11
 Re: Re: Int. 350 Utility in reply to Jon, 06-26-2000 17:14:17
It should be disengauged before going down a steep hill because when engauged you will freewheel. Very dangerous.
REDHUSKY91
06-27-2000 06:11:00
Andy
06-27-2000 10:56:23
 Re: Re: Re: Int. 350 Utility in reply to REDHUSKY91, 06-27-2000 06:11:00
I beleieve the exact term was "Torque Amplifier".....thanks for the feedback
