Farmall M
Bart
07-07-2000 13:43:46
I have a 1944 M with the magneto and the cut-out on the generator. Can I install a coil set-up, with a voltage regulator and a new wiring harness? I have the coil distributor set-up. Is it that simple? Can,t be, can it? All 6 volt. Thanks.
Andrew
07-08-2000 18:50:06
 Re: Farmall M in reply to Bart, 07-07-2000 13:43:46
Distributer and coil will take the place of the magneto. It is that simple. Also need voltage regulator. Recommend change system to a 12 volt battery, leave everything else 6 volt with the exception of the lights and put resistor in the line going to coil. You can hide the resistor and if no one ever looks at your battery, will never know it is 12 volt system. I have had one since 1986 this way and never had any problem with generator, starter, or regulator. PS Will crank better.
