Farmall 100 pops
Bill
07-08-2000 20:20:21
When running at any speed or under a load the engine makes a popping sound. Almost sounds like its skipping, but it is'nt. It does have some black smoke coming out of the exhaust when letting out the clutch (when engine revs quickly). I am suspecting carburator out of whack. If so how do you adjust it? What else could cause this.
Thanks.
Dave BN
07-08-2000 20:39:05
 Re: Farmall 100 pops in reply to Bill, 07-08-2000 20:20:21
Need more info. Do you have good power or have you noticed a loss of power lately? Does it do this when engine is cold or only when hot? Is the engine running too hot? Quick way to check compression is to pull coil wire off so engine won't start and turn it over either with a crank or with the starter and see if each cylinder has the same compression or does one of them seem weak. This info will help diagnose your problem. Dave BN
ltf in nc
07-09-2000 07:57:43
 Re: Re: Farmall 100 pops in reply to Dave BN, 07-08-2000 20:39:05
As previously stated, need more info. Is popping at a uniform interval or random? If it is uniform, you may have a bent pushrod or valve. If the popping is irregular, the problem could be improper point clearance, timing, or burned points. Irregular popping is typically electrical related and not carb symptoms. Gas symptons are failure to rev or make power, black smoke, hard starting, idle, etc, but not popping.
Post your findings.
Bill
07-09-2000 19:22:24
 Re: Re: Re: Farmall 100 pops in reply to ltf in nc, 07-09-2000 07:57:43
It pops when cold or hot. Engine does not run too hot. popping is irregular. There is slight lack of power. I will try points first, its been awhile since I've changed them. Thanks for the info.
Bama Binder
07-10-2000 13:05:56
 Re: Re: Re: Re: Farmall 100 pops in reply to Bill, 07-09-2000 19:22:24
My Cub "popped" when an exhaust valve would stick. When it was completely stuck it would pop at regular intervals...then it became intermittant...then it finally stopped as the valve progressivly loosened up.
Try this...with the engine at a low idle, place a gloved hand over the exhaust. Normally with the firing of each cylinder, your hand will be blown away from the exhaust. If however it gets sucked in once in a while, your valve is sticking.
I think in my case, the pop was from the uncompressed gas/air mixture either being ignited by the spark plug or from the exhaust from other cylinders. Let us know what you find out....Binder.
Dave BN
07-10-2000 19:25:02
 Re: Re: Re: Re: Re: Farmall 100 pops in reply to Bama Binder, 07-10-2000 13:05:56
I was thinking of a sticking or cracked valve also,or maybe a timing problem: points, overheating, etc. Dave BN
