F series Inheritance
B. Griff
07-11-2000 17:21:29
Recently inherited an F series farmall that belonged to my wife's grandfather. I have helped others restore and now I'd like to give it a try. I think it is an F20, but am not positive. The plate over the clutch is marked 1500DB with an F to the side and the IH symbol. I need help determining the year and model as well as whether it should be gray or red. Any help would be greatly appreciated.
Scott
07-12-2000 09:40:05
 Re: F series Inheritance in reply to B. Griff, 07-11-2000 17:21:29
The serial number plate should be located on the tool box that mounts on the clutch housing(under the gas tank). There is also a serial number on the engine on the left side. There is a flat spot just below the head to the rear. On my F-20 the serial numbers match but I don't think that is necessarily always the case. I have the serial numbers by year. On the color, IHC changed from gray to red in 1935. 35 and below gray, 36 and above red.
Dick Bowman
07-13-2000 18:42:07
 Re: Re: F series Inheritance in reply to Scott, 07-12-2000 09:40:05
If it is an F-20 the serial number will also be stamped on top of the left frame rail, just behind
the bellhousing mounting ear. FA will be the serial number prefix.
