Farmall A tranny seal
Brian
01-03-1999 09:03:45
While I'm at it, I need to replace the transmission input seal. Has anyone any experience in this area? I've had it split to replace the clutch, but never had the torque tube off the trans. It this straight forward? Ot will I need to disassemble the transmission?
Thanks for any help provided...
Dick DeYoung
01-03-1999 19:01:25
 Re: Farmall A tranny seal in reply to Brian, 01-03-1999 09:03:45
Once you have it split to replace the clutch, you will need to remove the pedal shaft to split the housing away from the transmission. Need to be pretty careful about this so as not to break the housing casing where the shaft comes through. My pedals were a real bear to get off because of all the rust and shaft distortions (from set screws). Once inside, the seal is pressed in a pretty fragile diecast housing that is bolted to the transmission. There are often as many leaks around the OD of the seal and between the casting and the transmission as through the seal lip.
Good luck.
Dick D.
Jim Becker
01-03-1999 19:39:04
 Re: Re: Farmall A tranny seal in reply to Dick DeYoung, 01-03-1999 19:01:25
As I recall, we always left the pedals and pedal shaft with the bell housing. Unpin the brake rods and unbolt the shaft supports from the platform.
