H Generator
1PWRFULH
07-17-2000 20:07:49
I took the generator on the H to get it fixed and the parts the guy put in(oil wicks) was only $1.50 and he said it was working fine. So we put the generator on along with a new voltage regulator. It is not charging any different than what it was before. What could be wrong? We are using an 8 volt battery. I need it charging so I can get the lights hooked up. Well thanks in advance!!!
RC
speed bump
07-18-2000 02:07:10
 Re: H Generator in reply to 1PWRFULH, 07-17-2000 20:07:49
be sure it is a battery that will take a charge,if it is too far gone it wont. just a shot in the dark . speed
speed bump
07-18-2000 02:08:12
 Re: Re: H Generator in reply to speed bump, 07-18-2000 02:07:10
speed bump
07-18-2000 02:09:46
 Re: Re: Re: H Generator in reply to speed bump, 07-18-2000 02:08:12
oops
Wayne Swenson
07-17-2000 21:31:40
If the generator is set up for 6 volt system, it will not charge an 8 volt battery!
Did the repair technician know what battery voltage you are wanting to use??
