22-36 Carb
Brian
07-19-2000 07:17:53
My friend has a beautifully restored 1929 22-36, and has been having carb problems lately. What he wanted me to ask all of you is what does the large thumbscrew on top and center of the carb do?
He normally when starting the tractor pulls two quick short tugs with the choke on and spark off, he then turns the choke off and the spark on and bingo she fires right up! But lately he's been having a harder time starting her and been getting some black smoke in the exhaust, this is something that is new and not normal. Your help will be greatly appreciated. Brian
Regularman
07-19-2000 09:11:40
 Re: 22-36 Carb in reply to Brian, 07-19-2000 07:17:53
The large thumb screw on the top of the carb is the load (main) fuel adjustment. Once it's warmed up, if the tractor is running to rich at full throtle, turn the screw in a little (very little at a time). The screw on the bottom of the carb with a spring on is the idle adjustment. If the tractor is running too rich at idle adjust this screw. Another common problem is float problems, the 22-36 has a cork float that can become saturated with fuel over the years. This causes the float to sink or partically sink causing the tractor to run too rich and flood-out when starting. If you need more help, let me know.
