Is my tractor an experimental farmall bn
bryon
07-19-2000 14:28:36
I have 4 farmall a's 2 farmall b's one of my farmall bn's was pianted white it also has a weird block their is no spot for a water pump but there is a hole like in a super a and c block for hydraulic pump just trying to find out if it is or is'nt a prototype. I have never seen a block like this and I own 16 farmall tractor in the letter seires.
Phil Auten (TX)
07-19-2000 18:50:43
 Re: is my tractor an experimental farmall bn in reply to bryon, 07-19-2000 14:28:36
Byron,
Someone probably replaced the block in your B with one from a Super A or a C/Super C. The white paint might mean the block came from a "white demonstrator" tractor or it could be what the person had on hand when it got painted. I doubt that this is an experimental tractor.
One way to find out is to find the engine number on the block and see if it matches up with the S/N of the tractor. I'd bet that it isn't even close, and I'd also bet that it fits into either the Super A, C or Super C S/N range, which would confirm my first theory that the engine is a transplant.
Phil
bryon
07-22-2000 06:17:05
 Re: Re: is my tractor an experimental farmall bn in reply to Phil Auten (TX), 07-19-2000 18:50:43
The engien is stamped with bn and for the super a or c thorie the engien does not have am place for a water pump. i would look up the tractor number but thhe seat was changed to the after market one with the shock.
