White bn
bryon
07-22-2000 15:33:35
motor has spot for hydralic pump but no water pump the motor is stamped with bn there is no seriel number on the tractor because the seat is was changed to farmall's more comfertable seat. The motoer is not like a super a or c motor because it doesnt have a place for a water pump. It looks to be the orginal motor.
Guy Fay
07-23-2000 08:09:19
 Re: white bn in reply to bryon, 07-22-2000 15:33:35
It could be a 48 BN- the changeover from the A and B and BN to the Super A and C resulted in many strange combinations.
What about your engine serial number. It should be on a flat part of the block right behind your ignition.
gene b
07-23-2000 03:17:41
water pump bolts on the block at lower return pumps can be put on ALL the blocks 90 for a new 80 for rebuilt longer fan belt needed probably a very late some C blocks were used on them I have a B this way INT did not have any other seats some companys made replacement types with a shock and spring have orig seats springs and bkts if interested live iN IOWA
big fred
07-22-2000 16:34:05
Not all Super A or C had a water pump, it was added after early production. However, no B's were produced with hydraulics. I would guess you have an early Super A or C engine in a BN.
bryon
07-23-2000 16:47:08
 Re: Re: white bn in reply to big fred, 07-22-2000 16:34:05
but the blocks seriel number is stamped with bn in it
Stan(VA).
07-24-2000 04:31:17
 Re: Re: Re: white bn in reply to bryon, 07-23-2000 16:47:08
I saw a very late straight A once (ser num above 200,000) with the original block that had the hyd pump cutout with just a blockoff plate on it. My guess is that the Louisville built A's and B's might have had a later revision of the block? The water pump would just replace the lower radiator neck below the generator.
Stan(VA).
