M HEAD Numbers
Bill
07-31-2000 07:54:22
My M is a 42. I'm having to replace the sleeves and pistons. Went to the machine shop to get my head back and they found lots of cracks in it. So I'm looking for a head. I recall a post that give some numbers as to which heads were good and which one were no so great. I looked around in the archives but diden't have any luck. The head I have has 8574 D B stamped just to the right of the temp gage sender. Is this the number location? Second thing is I need new sleeves and pistons is there any reason NOT to go with the Firecrater pistons? And if so does that change which head a guy uses.
sammy the RED
07-31-2000 19:27:25
 Re: M HEAD Numbers in reply to Bill, 07-31-2000 07:54:22
Your 8574-DB is a gasoline head.
Les Repair
07-31-2000 17:51:46
A gas head for a M has the number 8060D cast inside the valve cover on top of the head. Yours might be a kerosene head. If you need valves you would be better with a gas to utilize the gas we have today. Definitely go for the domed pistons.
Jim
07-31-2000 08:32:56
I would have a head for your tractor.
Email me .
