Carb on F-14
Barry
07-31-2000 08:59:14
I am having alot of trouble with my F-14 flooding out.I have rebuilt it and it still floods.I have also done some gasket work on the governor and replaced a few components in there with the same result.I am out of ideas.Now what?BTW,I have new plugs,W-20,good wires and mag,new points,condensor and all.
Alex
07-31-2000 09:09:53
 Re: Carb on F-14 in reply to Barry, 07-31-2000 08:59:14
The most likely reason for flooding is a stuck needle valve. Try replacing it and make very sure that the float doesn't bind or rub on the sides of the bowl. I had the same trouble. You may need to adjust the float level by bending the little lever or better still put another gasket under the needle valve seat so it sticks down further. This worked for me.
