Live Hydraulics on Super M
Brandon Peters
07-31-2000 17:33:37
Is it possible to put live hydraulics on a 1952 Super M with the 264 ci engine?
ND David
08-02-2000 05:25:49
 Re: Live Hydraulics on Super M in reply to Brandon Peters, 07-31-2000 17:33:37
Brandon, the pump you want fits right behind distibutor. These pumps are very efficient and give you instant live power. However, when you find one and install it, critical you that you install correctly to insure dist does not get out of time but thats about as complicated as it gets. Good Luck.
Wardner
07-31-2000 19:21:26
It was a factory option so you should not have any problem locating one and installing it.
S-E Michigan Part Timer
07-31-2000 18:34:40
Sure can.. Some type of kit that fits in front of the distributor. Mine's had one since the mid 50's. Look thruough the links on this page, somewhere I seen one advertised. Could also check w/ your local salvage yard.
