Farmall M charging and discharging????
al
08-01-2000 16:27:12
Farmall M
rebuilt generator, rebuilt starter, new regulator.
Now getting a charge, before wasn't, BUT half thottle charges ok. less than half starts to discharge, lights on discharges, bright lights discharges even more!!! Have only three postions on switch off, dim, bright. battery ignition 6V system
age of machine unkown plate is gone. I am new at this working on tractor stuff; this is the machine i learned to farm with(busted fingers and all(narrow front end plowed fields, etc.)
Any suggestions would be greatly appreciated!!!!! have to leave now will not be able to check back till later this evening or tomorrow a.m. Thanks in advance.
The Red
08-02-2000 04:11:58
 Re: farmall M charging and discharging???? in reply to al, 08-01-2000 16:27:12
Al remove the cover from the voltage regulator. I bet the points are opening up too early as you decrease the engine RPM. You can make an adjustment on the spring tension so you charge at lower RPMs. Make only a very minor adjustment or the points might stay closed after you shut down resulting in a battery being drained very quickly.
al
08-02-2000 11:02:51
 Re: Re: farmall M charging and discharging???? in reply to The Red, 08-02-2000 04:11:58
Thanks will try when return from short vacation.
Kenny C. (FarmallCaseKid)
08-01-2000 16:46:22
I have the same thing going on with my C, it also has a rebuilt starter,generator,and a new regulator,but mine is 12v. So can someone help me out also..... thanks,and I hope you get some replies too Al
08-01-2000 16:48:10
 Re: Re: farmall M charging and discharging???? in reply to Kenny C. (FarmallCaseKid), 08-01-2000 16:46:22
I just don't have that throttle problem.
