53 Super M
Brian
08-03-2000 18:53:36
I have a 53 super M and I am totally clueless on how the hydrolics is suppose to be. I have a resevoir under the gas tank. It has four hoses that comes out of the res. two come from the pump that is running from the pulley. They 1-1 1/4 lines. The other side have 1/2 hose that come out of them. Then I have two hoses on the aux valve. Can anyone help?
Wardner
08-04-2000 15:26:16
 Re: 53 Super M in reply to Brian, 08-03-2000 18:53:36
You have an IH "Lift-all" system with a "remote control auxillary valve". The 1" return line and the 3/4" pressure line from the pump are 'teed' into the remote control valve and then continue to the reservoir/lift-all valve combination unit under the gas tank. Those connections are all on the right side of the tractor. It appears that you have an aftermarket PS pump mounted on the left side of the engine. It should be connected to an actuator somewhere on the steering shaft. There is no place to plumb it into the reservoir unless it is teed into the previously mentioned hoses. I have never seen that done. The two 1/2 hoses out of the remote valve are usually connected to a double acting cylinder. There are three other pressure ports on the system. They will be located near your left foot when it is on the clutch pedal. A parts manual can illustrate and describe all your parts except the PS unit.
