To start, or Not to start ?
Bill Wehrman
08-15-2000 13:44:41
Should a person even try to start an engine that has not run for a few years? I have a WK-40 and an AC 20-35. Both have good compression and all the controls are free. Both apear to be pumping oil. I have started F-20s and Model Ts after long rests, but they are not quite as hard to find parts for and I never worried about it. Would you light them up or tear down for inspection and cleaning first? Thanks Bill
Randy Reed
08-15-2000 19:49:57
 Re: To start, or Not to start ? in reply to Bill Wehrman, 08-15-2000 13:44:41
You might try adding a teaspoon of Marvel oil in each cylinder before you turn it over the first time. Might save you a scratch or two on your liners. You can get it at Walmart.
Heck yes start it! Philip Croff
08-15-2000 18:45:29
Why not start it? If it's not stuck and has all good fluids, nothing is wrong with starting.
RB
08-15-2000 15:19:10
Shoot yea!Fire em up.How ya gonna know if they are ok if you dont.Besides which are they doing anything just sitting there?"Itll make them fell good"to be run again.
F14
08-15-2000 14:03:11
My opinion (which, with a buck will get ya a cuppa coffee in a cheap restaurant): Check the air cleaner and intake for dauber nests, douche out the gas tank, sediment trap and lines with fresh gas, change the oil, spin 'em over with the ignition (mag, whatever) off to oil 'em up, and light 'em off!
Oh, and...
08-15-2000 14:04:07
 Re: Re: To start, or Not to start ? in reply to F14, 08-15-2000 14:03:11
ya might want to add a compression check to that to make sure the valves are working...
