300 farmall TA
Brian in MO
08-24-2000 17:44:39
I watch this forum frequently lots of good info. I am in the middle of putting a TA in my 300 farmall and was wondering if there is anything else I should look at while I'm in there. Thanks for any info. I am also replacing 4th & 5th sliding gear (wore out).
Wardner
08-24-2000 19:32:53
 Re: 300 farmall TA in reply to Brian in MO, 08-24-2000 17:44:39
You might want to check the splines on the IPTO Driven Gear. It is the first gear on the lower shaft. If it wobbles, it and/or the shaft should be replaced. This is a common problem on the bigger tractors but may not be an issue on a 300.
R Rahmier
08-24-2000 18:52:40
I did two 450's this year and on both of them I took the platform off to look for bad bearings I found on one the inner axle bearing serveral balls gone and the inside race broke in half the other one had a bad pinion bearing in it
Brian in MO
08-25-2000 19:30:12
 Re: Re: 300 farmall TA in reply to R Rahmier, 08-24-2000 18:52:40
Thanks for the info guys I'll be sure to check that I am planning to take the floor up for a look anyway. Thanks for the ideas. Brian
