Thermostat Gasket
BTD
09-01-2000 09:44:56
I am replacing the thermostat on my M and the instructions mentioned a gasket (logical), however, no gasket was included. Can I use Permatex or should I make a gasket? Thanks!
BTD
BTD
09-02-2000 18:00:53
 Re: Thermostat Gasket in reply to BTD, 09-01-2000 09:44:56
thanks for all the help guys! I will replace (or put in place if one is not there) the thermo. tomorrow.
BTD
Bob M
09-01-2000 10:33:40
BTD - I replaced the t'stat in my Super H a couple weeks ago. Didn't have the right gasket either. Instead I simply scraped the mating surfaces clean, wiped them with some brake cleaner then put a thin layer of Permatex Hi Temp (red) RTV gasket maker on both surfaces. Bolted everything back together and it works perfect - no leakage whatsoever.
T_Bone
09-01-2000 19:46:50
 Re: Re: Thermostat Gasket in reply to Bob M, 09-01-2000 10:33:40
Hello BTD, Reguardless if I have a gasket or not I always use red RTV for a positive seal. Gaskets have to be used when the mating surfaces are not matched close enough. Less RTV is better than more when applying to surface. I haven't had a after leak in years doing it this way.
T_Bone
The Red
09-01-2000 10:06:11
BTD I make a gasket out of a blank that I buy at NAPA. It has the adhesive on one side so you can plop it on there and start cutting. You can get a formed gasket from IH if you prefer.
