Driver pin removal
Bruce
09-04-2000 07:07:50
I'm having trouble removing the driver pin from the end of the water pump shaft on my 46' H. Can someone tell me if this pin is threaded into the driver and shaft? I removed a jam nut, but the pin won't budge. Is there a secret to this?
The Red
09-04-2000 11:16:36
 Re: Driver pin removal in reply to Bruce, 09-04-2000 07:07:50
Bruce those can be a pain at times. Stick the nut back on until it is flush with the end of that tapered pin. Use penetrating oil first then use a flat head punch and give it a few good whacks.
Farmer Bob
09-04-2000 09:28:24
Bruce, Cancel my reply on this thread and use the one down a few inches....not awake yet and thought you were talking about the crankshaft pin. Sheeesh! That's what I get for not splashing cold water on me face first thing this mornin. FB
Farmer Bob
09-04-2000 08:58:58
Bruce, Look on either side of the shaft where the crank pin is located for a set screw that's holding the pin in. It will be there under some grease and dirt so look close. It sits perpendicular to the pin kinda like this -:- Should have a slot for a screw driver for removal. Good luck..FB
